Re: 140 distributor advance question
Posted by D Slater on February 11, 2012 at 12:12:34 from (184.15.54.166):
In Reply to: Re: 140 distributor advance question posted by randy hall on February 11, 2012 at 11:56:01:
Randy its a 22 degree max at the crankshaft. Was looking for the in between degrees to compare to others. Most times information will have the distributor RPM and degrees of advance listed at 200,400,600,800 or more if the engine RPM is higher. Advance springs for that distributor advance are almost twice as much as some others I think are close. Thanks
