Posted by The tractor vet on February 11, 2012 at 13:40:04 from (75.19.121.190):
In Reply to: 706 wont start posted by Diesel1 on February 11, 2012 at 07:30:29:
Well you may have the dist set accordingly to the oil pump but you are more then likely 180 out . If you say you have the timing marks correct and the rotor set at #1 then it will run. Now as not having the FUEL SHUT off solenoid in place ya had best get it back in place as it was put on them tractors for a reason . You did not say if this is a C 263 or a C291 . Timing has to be set for the engine as they do not set the same. Next do you have it wired correctly ?? Myself i have never had one that did not fire the first time even if i was a little late or a little advanced on the timing.
