Re: Compression readings for a MD??
Posted by Machine249 on February 11, 2012 at 13:55:37 from (76.100.246.141):
In Reply to: Compression readings for a MD?? posted by lbg57 on February 11, 2012 at 12:42:40:
I've never seen an actual number for compression readings. I've always seen something along the lines of "if readings for each cylinder are within 10% of each other" then your good. If it helps at all both my 504 and my A readings are around 130-150psi... These are both gas engines so a diesel maybe more. Hope this helps.
