farmall m tire sizes
Posted by jdetig1 on February 11, 2012 at 15:19:45 from (50.45.127.159):
I need some rear tires for my 1950 farmall M. The ones on it are 13.6x38. I have some pretty old 15.5x38s on a set of clamp on duals. I measured the width of the 13.6s and 15.5s and they are the same width across or very close to the same. I also measured the width of both rims the best i could and they were also very close to the same. So is there any reason that i cant put those 15.5s on my M? The 15.5s dont look nearly as wide as the ones on our 656. could there be a difference because the tires are really old?
