Use glow plugs always, even if l00 degrees out. Pre cup engines have to have a outside heat source to ignite fuel until sufficient heat and turbulence is created. It may well start when warmed up , shut down and immediately restarted without using glow plugs but then again five minutes later it most likely won't at least with out missing and fooling around. Do not even think of using ether if you are using glow plugs as it may well blow the whole intake manifold off because at least one intake valve is open all the time. Make sure all six glow plugs work. Hold them for a full minute and keep holding them when starting because they will cool off in 5 seconds. A good pull , even on a worn out engine, should get it running if glow plugs are working. And pull the throttle wide open to start.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development
... [Read Article]
Latest Ad:
[More Ads]
