.060 over pistons for a D301
Posted by Spencer 460 on February 11, 2012 at 17:00:41 from (107.8.91.35):
I am in need of one piston for a D301 that is .060 over the original 3 13/16" bore. This diesel engine has Zollner pistons in it. The D301 is in a 460 puller I bought and it was parked in a barn for several years and the #2 piston has been pitted from moisture collecting in the pipe and running through the head and sitting on the piston.
