glow plugs is a must or forget it. these are very easy starting engines once a person knows them . either , throw that in the bush cause it will cost you big money in the end. dont matter if its 80 degrees still need to use glow plugs. hold for a minute and even once running till smoke clears up. i would say you would have to pull it 1/4 mile before it would finally start without glow plugs. its just the way they are designed, use glow plugs.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
