Re: Water pump bypass
Posted by TractorJohn on February 11, 2012 at 21:58:38 from (24.29.48.243):
In Reply to: Water pump bypass posted by Machine249 on February 11, 2012 at 19:18:18:
The bypass keeps the water circulating in the engine when the thermostat is closed to avoid hot spots. It's a good idea to have it.
