Posted by Janicholson on February 12, 2012 at 08:42:43 from (96.24.99.126):
In Reply to: Water pump bypass posted by Machine249 on February 11, 2012 at 19:18:18:
The thermostat bypass should be no more than 1/4"diameter. If there is more than that the tractor will not get to operating temp. If the thermostat is placed on the head like it is in most 2000 and many older engines (of all types), the thermostat bypass need only be that tiny loose stud in the thermostat. But if your design has both a water pump bypass of about 1/2" hose and a small thermostat bypass, all is well. If you are talking about a water pump bypass that does allow water to circulate in the block. it is important. Jim
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
