The top one in the picture is from a lower pressure older tractor. BUT, the bottom one is also made in two different size rods. I can't tell from picture which one you have but the smaller rod is for higher operating pressure used on later higher pressure systems to obtain higher unlatching pressures. You will find them mixed and matched depending on who worked on tractor or who added valves. You almost have to have both the rods side by side and measure to know for sure which one you have. At any rate, you will have to find the o-rings and back up washers that fit the pin to repair valve. The top style, pin comes with o-ring on it as o-ring is so small you break a lot of them putting them on.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
