Re: 460 brake question
Posted by Heat Houser on February 12, 2012 at 18:45:00 from (69.66.35.73):
In Reply to: 460 brake question posted by jaxx fann on February 12, 2012 at 18:10:23:
On my 560, I smeared a bit of hi temp grease on the ramps the balls ride in...sparingly.
Also cleaned and greased the 3 areas (on the OD of the "expander")where the center "expander" contacts the outside cover. These three areas keep the "expander" centered in the outside cover and centered on the brake discs.
Also sanded smooth the outer cover, both sides of the "expander" and the inner quill to eliminate any machining marks. (where the brake discs contact)
So far, they work well.
