Re: H bearing 8097D
Posted by david G on February 12, 2012 at 18:59:58 from (205.215.206.18):
In Reply to: Re: H bearing 8097D posted by Nebraska Kirk on February 12, 2012 at 18:52:30:
Kirk, I was thinking about that. I need to do same on MH 44, the
shafts are the same diameter. Would you try that with a drill, or
take to machine shop. I can turn bushings,
