The little cup, back up washer and 0-ring are right inside of the threaded portion on that lower one . If it has none, no wonder it leaks. Has to have an o-ring inside for pin to seal on. If you have a service manual it will show how you pull the cup out of actuator. And, yes, you screw in to increase unlatching pressure. Here is how I do a quick adjustment of the pressure to suit my own needs. After valve is fully assembled, engine running, lower hitch all the way, put position control lever all the way down into action control which dumps most of the oil going to aux valve , pull valve to latch, then pull position control lever to raise position and valve should unlatch. Keep turning set screw in until it will not unlatch, and then back it off again until it consistently unlatches. You are supposed to use a flow rater of course but that is another story.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
