Re: Live Hydraulics on a M?
Posted by Janicholson on February 12, 2012 at 19:07:43 from (96.24.99.126):
In Reply to: Re: Live Hydraulics on a M? posted by david G on February 12, 2012 at 18:53:17:
D Slater indicates the following:
If your tractor is a 1950 there's a engine serial # break on the front cover and plate to the correct bolt pattern for the IH pump. If its older the bolt pattern is different. If newer the same bolt pattern as IH pump. On some M front covers though the pump shafts with snout for a hour meter drive gear will contact inside of cover just before a flush bolt up. This is just a guess on engine serial # break without looking it up, but I seem to remember it may be 228050.
