Re: Water Pump For C
Posted by Daniel on September 11, 2000 at 10:22:26 from (206.74.50.21):
In Reply to: Water Pump For C posted by Clint Proeschel on September 10, 2000 at 16:22:32:
The pump bolts on in place of the lower water neck, should be an easy swap, just be sure to have a new gasket handy.(IH still has them) Also, you will need a longer belt, too. You have another problem if your C is overheating that quick. I would flush out the block amd possibly have the radiator boiled out. The pump will help circulate the engine flush, it dosn't work too well on a thermo-siphon system. Good luck.
Post A Followup
: Re: Re: Water Pump For C
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
