Re: Live Hydraulics on a M?
Posted by mkirsch on February 13, 2012 at 05:36:02 from (64.80.110.75):
In Reply to: Live Hydraulics on a M? posted by onefarmer on February 12, 2012 at 18:40:03:
You don't need to change out the front cover or cam gear for an M&W pump. They were designed to fit the older style cover.
The problem with an M&W pump is, you're stuck with what you get. If you buy a junk pump, there's no fix to it. No parts.
Buying a used IH pump is also a huge risk, because you can't fix these either. Once it's wore out, it's scrap.
The only way a used pump will work is if you can find a salvage yard with a supply of them, and work out a deal where you can keep trying them until you find a good one.
Either way, you could very easily end up out hundreds of $$$ with nothing but a lump of scrap to show for it.
Safest bet is a NEW IH pump. Not cheap, but after 2-3 dud used pumps, about the same money.
