Posted by old on February 13, 2012 at 09:22:55 from (209.86.226.59):
In Reply to: Cub,,,,Overheating posted by Kyrock on February 13, 2012 at 09:16:04:
Drain and use a vinegar flush in the system. If it sat with coolant in it and you did not change it or you change it with out flushing it you could have a lot of rust etc in the cooling system. Drain it out then fill with vinegar and run it till good and warm let sit so as to be safe to drain it out. Drain it then hook a hose to the block drain and back flush it with a garden hose. Also spray out the radiator it self with the hose
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
