Re: Super C Hydraulic Reservoir Vent
Posted by Haas on February 13, 2012 at 13:10:29 from (75.200.183.73):
In Reply to: Super C Hydraulic Reservoir Vent posted by T Brown on February 12, 2012 at 10:27:10:
There is no vent on the hydaulic reservoir. Always take the fill plug out first when you do any maintenance that requires draining the reservoir. For some reason, pressure builds up in these and bleeds off really slow. I forgot this on my C when I split it to change the ring gear on the flywheel. The tractor had not been run for weeks and I took out the drain plug first and got the oil bath as some of the others here described.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
