Myself i have never done a narrow rim , i have done several 12 inchers. as you have a nice flat area to split and ya split the side away from the hole for the valve stem . I have a weld shop that has rolls that make me the bands and they always make them and inch or so longer . Then ya just place them on the rim and tack then ya put the bead on the band and tack it . Oh one other thing here always put indexing marks on both sides of the cut and keep them aligned . I also like to keep a little air gap between the band and the rim and bead part of the rim so that when welding ya get 100% penetration. Then also weld both sides . Keeping weld build up down saves time grinding . I cut the rim mounted on the tractor and use a steady rest to get the best cut and as straight as i can the indexing makes help with keeping the cut in register . I prefer M I G welding over stick but i can do it either way. With mig i run l56 and AG 25 with stick i use 7018 After i have it all tacked together it goes back on the tractor and is welded there . I have split both 34 and 38 inch rims . On the newer style rims that have the double mounting ribs we split them down the middle between the ribs.. But on the old 12 inch rims on M's we just split the one side . On my S/MTA i put a 4 1/4 inch band in it to mount the 16.9's . You ask why a 4 1/4 inch band ?? well by the time you make the torch cut and grind you can loose more then a 1/4 inch easy i was a 1/16 th short of 16 inches when done .
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
