I widen my 11" rims to 14" rims on my super M. Made a guide for the plasma cutter to set against the bead and rolled the rim till I cut it in half. Used 7 ga (3/16 metal) 3" wide rolled into a ring and put it back together. Welded it inside and outside with the mig welder. I then put duct tape over the beads on the inside so it would not pop the tube. What took the longest was grinding down the weld bead so you would not see it on the finished rim. Holds up good when I tractor pull. I put 15.5 x 38 back on mine.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
