Posted by mkirsch on February 14, 2012 at 12:08:19 from (64.80.110.74):
In Reply to: trade? posted by jackinok on February 14, 2012 at 06:57:42:
With trailing implements, a good H will run circles around an N-series Ford any day.
General wear and tear is the only "weak spot" that an H would have. Look it over good. Give it a workout in the field. Watch for smoke. Listen for creaks, pops, and groans that may indicate bearing problems in the rear end.
When someone comes to you proposing a trade, they usually feel they're getting the better end of the deal. Be sure he's not trying to pawn off a basket case on you.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
