Posted by Owen Aaland on February 14, 2012 at 14:52:55 from (216.47.34.216):
In Reply to: 460 engine swap posted by tntleake on February 14, 2012 at 13:56:51:
The C263 will be fine as long as you are not doing a lot of heavy pulling. If the tractor is late enough it would of had the updates from the factory and there will be no additional stamp on the serial tag.
Without the original engine to get parts from you are going to be short a few things to put it in a tractor. You will need a font cover and backing plate from a 460/560. You will need a different rear plate to mount to the clutch housing.The exhaust manifold and carburetor are different. The oil pan is different though you probably use the combine pan.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
