Re: Farmall M Throttle linkage
Posted by pete 23 on February 14, 2012 at 17:45:33 from (74.32.238.142):
In Reply to: Farmall M Throttle linkage posted by Tim in E-VILLE on February 14, 2012 at 14:17:07:
When someone is not familiar with that linkage bolted to the head it is pretty easy to assemble it incorrectly. Like Slater said, when you pull throttle lever back toward you on seat, it should push the rod behind manifold down and it should push it far enough down to bottom out on the set screw in the governor. When full forward it should touch upper set screw for idle position and spring should hang loose.
