Hydro pumps should last well. If the mount, or alignment is off even .002" the bearings will wear. If there is abrasive in the oil, the screen will not take it out, oly a real filter will remove the grit. The governor probably has a stickey shaft, or throttle shaft causing it to stick. Disassembly is probably needed, cleaning, then relubricating with moly grease on the shafts and pivots. (not inside the case) Jim
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development
... [Read Article]
Latest Ad:
[More Ads]
