Re: auxillary hydraulics needed on 300 Utility
Posted by AJB-830 on February 14, 2012 at 19:29:18 from (50.105.149.123):
In Reply to: Re: auxillary hydraulics needed on 300 Utility posted by neilc on February 13, 2012 at 18:14:13:
third party image
third party image
third party image
Neilc, I took a couple of pictures of the 3 valves on the 300 utility. Pictures are not the best because I have the winter heat houser on it and couldn't get any side pictures. The valves are connected by a pipe that originates from the flow divider/regulator. Not sure if this pipe is because of the P/S or if all 300's have this. If you don't have this pipe on your single valve, maybe you can just add the 2nd valve to it. Basicly on a row crop the 3 valves are all bolted together. Send me an email if you have more questions. Hope this helps. Al
