Posted by oldtanker on February 15, 2012 at 06:03:56 from (66.228.255.223):
In Reply to: trade? posted by jackinok on February 14, 2012 at 06:57:42:
The H tested at 24 HP drawbar and tips the scales at 3875 lbs.
The N tested at 21 HP drawbar and is 2410 lbs.
While I would give 2 cents (cause the scrapper will pay a lot more) for an H I turned one down, wide front, live hydraulics, after market 3 point and loader for 1500 just last month in overall good shape. Included a set of chains too. Reason is that it just don't fit my needs. My N fits a nitch here on the farm just fine but the H is too tall for some of the things I need. The H was a great tractor but unless you have the implements it's about worthless today for most farming apps without a 3 point. I'd trade my N in a heatbeat for a slightly bigger utility tractor with more HP.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
