Re: eletric trailer brakes
Posted by Michael Soldan on February 15, 2012 at 17:10:26 from (24.235.50.240):
In Reply to: eletric trailer brakes posted by jim warehime on February 14, 2012 at 18:24:51:
as was suggested a bad bearing could cause the drum to contact the shoe,but....a siezed adjuster,an adjuster set too tight, a siezed activation arm, a bad magnet,a bad wire..could be one of many factors..get the drum off,clean everything up and lube all areas that have a moving part or need to move with anti sieze. A bad magnet will be bluish in color from over heating,the face of the drum should be shiny indicating that the magnet has put drag on the actuation arm..most problems I find are rusted siezed parts that will not allow proper application and release of the brake shoes.
