Re: Seals in steering housing on Farmall 100
Posted by Janicholson on February 15, 2012 at 20:05:08 from (96.24.99.126):
In Reply to: Seals in steering housing on Farmall 100 posted by RDJ Farms on February 15, 2012 at 18:56:32:
THe newer style seals might be thin enough to put in two in the same space that formerly held one. I would do it that way. Pack chassis grease between the two seals to assure the outer one is lubricated. This also has the benefit of placing the lips of the seals in different locations on the shaft instead of the groove made by the old seal. Bottoming is fine, if the second seal sticks out a bit so be it. Jim
