Re: spring clip
Posted by Janicholson on February 15, 2012 at 20:27:42 from (96.24.99.126):
In Reply to: spring clip posted by Roy Prins on February 15, 2012 at 16:22:02:
find a piece of banding steel from a shipping carton and snip one out. Aneal it in a propane torch flame till red, then set it in some ashes or wood chips, and let it cool slowly. Then take a nail and vice grip pliers to curl the pin hole loop and spring curve (make it about 3/8" longer than the original) about a total of 2" with the bend at 3/4" from the pin loop. Then heat it again and quench it in water. It should regain its hardness. If it breaks, temper your next try in oil. Jim
