Re: F14 Questions
Posted by Daniel M. on September 11, 2000 at 19:50:17 from (205.163.39.210):
In Reply to: F14 Questions posted by JRM on September 10, 2000 at 08:44:05:
JRM,I just repaired both of these items on my F-14,on my steering coupler it was a pin that was staked into place,I had to drill it all the way thru to relieve the pin so it would move with a punch and hammer.I heated the spline and tapped with a punch and hammer ond off it came.The clutch pivot is not welded but pressed in,mine was also worn out and I could not get it out either,so out came the drill again.I drilled thru the center,being carefull to stay in the center and staight.I drilled the 5/8 pin out with a 1/2 bit and got under what was left in the hole with a center punch an worked it out.Now the other problem is the pedal is probably worn also,so what i did was to drill and tap the pivot hole to 3/4 and drilled the pedal hole to 3/4.Then i threaded a bolt with enough shank to fit the pedal and tightend in place with loc-tite,I cut the bolt head off and drilled a cotter pin hole and mounted the pedal.You cant even tell its not stock. hope I helped, Daniel M.
Post A Followup
: Re: Re: F14 Questions
