Re: 560 and 656 same engine?
Posted by ejr-Ia. on February 16, 2012 at 08:49:42 from (204.11.182.14):
In Reply to: 560 and 656 same engine? posted by GR Gold on February 16, 2012 at 07:55:50:
You are working with the same engine family.All you will need to do is change the front timeing case cover,just swap the two out.Other minor things carb,maybe the govenor and linkage the air cleaner off the 656 will go on the 560 motor.The motors are the same cid,HP and rpm.Fairly easy swap.
