Re: Trying to locate Farmall H main bearing kit .002 und...
Posted by gene bender on February 16, 2012 at 13:51:57 from (67.55.226.168):
In Reply to: Re: Trying to locate Farmall H main bearing kit .002 und... posted by rustyfarmall on February 16, 2012 at 13:28:24:
The undersize means the crank has been ground undersize so the bearings are oversize from standard as there isnt any undersize bearings unless you build up the crank over standard then you could use an undersized bearing from standard.
