Re: F-20 Carburetor Seepage
Posted by 38F-20 on February 16, 2012 at 17:50:57 from (134.161.72.81):
In Reply to: F-20 Carburetor Seepage posted by 38F-20 on February 15, 2012 at 15:33:13:
I believe the only RTV is between the carb and manifold gasket. There is not any in the body of the carb. What do you guys recommend to use as a sealer around gas or petroleum products instead of RTV? I typically use either Yamabond or RTV black, but reached for the red container when I was putting the carb on.
Like some have mentioned, I already turn off the fuel whenever it's going to sit for a few hours. I normally run the gas out of it when it sits for more than a day or so. I've got about every other leak fixed and just want to complete my restoration with a clean, dry carb externally. I'm just out of good ideas and thought I would get some other input. Thank you.
