Problematic O-Ring
Posted by Jason Hubner on February 16, 2012 at 18:01:23 from (64.9.127.207):
I'm trying to replace a o-ring inside the 3pth lift housing on my 504 but can not remove the shaft that the o-ring goes on due to unmovable parts in the way to slide a new one on. My question is can i cut the new o-ring and wrap it around the shaft? The shaft with the o-ring only rotates, it does not plunge back and forth. Whether that matters or not. And the fluid behind the o-ring is not under pressure. Any suggestions? Thanks.
