Re: 560 and 656 same engine?
Posted by RPM1941 on February 16, 2012 at 20:50:55 from (173.24.196.59):
In Reply to: 560 and 656 same engine? posted by GR Gold on February 16, 2012 at 07:55:50:
They are similiar, take same gaskets, but 656/706 C263 has a combustion chamber shape that is different, as stated other replies it will fit, but be advised that dome of piston is specific for later tractors, also head casting, I would agree that LP is higher compression, if you lived in higher altitude such as Colorado might work.
