Re: Gas Tank pads
Posted by rustyfarmall on February 17, 2012 at 08:07:16 from (216.248.71.224):
In Reply to: Gas Tank pads posted by west alton river rat on February 16, 2012 at 14:44:01:
Just remember that whatever pads you use under the tank need to be the same thickness as what is under the radiator or the hood will not fit right, and if the wrong thickness is used under the radiator, there will be a clearance issue with the steering shaft where it passes through the radiator.
