cub fender removal
Posted by bearcat1 on February 17, 2012 at 10:47:45 from (184.35.74.179):
My fender on my 53' cub is held onto the axle by four bolts that also serve to bolt the inner axle to the outer part of the axle. There are two more bolts on the lower part of the axle also..can I safely remove these four bolts with out damage or breaking a seal? would it be better if I removed the wheel to lessen the weight before removing the four bolts. any thoughts? thanks
