Re: Fermall M
Posted by F-Dean on February 17, 2012 at 10:51:22 from (166.248.139.79):
In Reply to: Re: Fermall M posted by bigfarmerjd on February 17, 2012 at 07:49:27:
The front end of an M is notorious for climbing, especially in 1st gear. If you must go up a steep incline, use 4th gear.
I once was saved when the picker elevator hit the ground and stopped the front end from climbing any more!
