Like the other guy said you will have to replace the whole cluster. On my 1256 I took a 6" by 6" piece of aluminum and used a hole saw to cut the proper sized holes for a temperature gauge and an oil pressure gauge. I bent the top 2" at a 45 degree angle and drilled two 1/4" holes in that top two inches. I bolted this piece to that access door down by the platform in the center. I installed a temp gauge and an oil pressure gauge. Now I can glance down at anytime and check temp or oil pressure. I wanted an oil pressure gauge instead of an idiot light and the temp gauge in the cluster didn 't tell me a whole lot. I like regular gauges for temp and oil pressure. If you want I might be able to email you a pic of what I did.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
