Re: Farmall 560 good news. And some not so good.
Posted by ejr-Ia. on February 18, 2012 at 08:32:30 from (204.11.182.14):
In Reply to: Farmall 560 good news. And some not so good. posted by Andrew Psencik on February 17, 2012 at 15:57:45:
The two middle exhaust valves sit beside each other in the head sometimes they burn out between them will make that noise.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
