Re: Starter on an H
Posted by pete 23 on February 18, 2012 at 10:05:24 from (74.32.238.142):
In Reply to: Starter on an H posted by John V on February 17, 2012 at 21:51:24:
The insulators would be on the power stud and we normally replace them when rebuilding a starter if field coils are removed. Like others have said, do not allow that stud to turn when tightening the cable down, hold onto the cable so it cannot turn. If the stud turns it breaks the solder loose and some times even the ends of the fields. Only good way to repair it then is to remove fields and stud. Took me a while to develop a good method of resoldering them as it seems no one around here fixed them, replaced starter.
