Re: 756 Loader Question
Posted by Armand Tatro on February 18, 2012 at 16:15:32 from (98.227.26.140):
In Reply to: 756 Loader Question posted by flhr62 on February 18, 2012 at 06:34:47:
Like Delta Red sayes the 4020 and the 756 are designed with side rails for mounting implements to. John Deere designed the 148 loader with sq. tubing so DO NOT CHANGE OR ALTER the main frame of the loader! I would only alter the holes in the mounting if needed. I would definatly add a frame to allow the rear axel to let the rear axel housing do the pushing as the older loaders were designed. I have used a i48 on a 4430 and it is an excellent loader as designed but if I was doing a lot of heavy pushing I would want some of that stress on the rear axel housing but that is my thoughts.
