Re: WD9
Posted by sflem849 on February 19, 2012 at 04:45:32 from (166.181.3.29):
In Reply to: WD9 posted by Al in Mn on February 18, 2012 at 19:17:51:
I lied, it is right behind the injection pump. I will post a picture, maybe you can see it.
third party image
You can't really see the number, but you can see the location in this picture. It is a few inches below the middle bolt for the front water jacket cover.
If you are looking for the engine S/N it is in that area, too. It is above the water jacket cover on that machined flat area. I would say it is right inline with the #1 cyl.
This post was edited by sflem849 at 05:01:26 02/19/12 2 times.
