Re: 460 utility steering gear
Posted by Rich in IN on February 19, 2012 at 19:21:04 from (199.16.223.2):
In Reply to: 460 utility steering gear posted by 53H on February 19, 2012 at 18:04:14:
Sounds like shaft nut is loose next to steering valve, should not move that much. Had a 460 diesel with D301 from a 715 in it, steering wheel would move up and down maybe 1/4 inch, worked OK.
