Re: uc-263
Posted by Owen Aaland on February 20, 2012 at 11:09:09 from (216.47.34.216):
In Reply to: uc-263 posted by farmerboy on February 19, 2012 at 16:37:02:
It depends on what you mean by standard C-263.
Tractor engines had replaceable sleeves installed and six threaded rear plate mounting holes. Replacement and other engines were sleeveless and no threads in four of the the rear block holes.
There are some other differences depending on block serial number such as crankshaft thrust bearing, cylinder head locating dowel pins, and cylinder sleeve style.
Basically they will all interchange.
