Re: Farmall tractor gas line problem
Posted by kevinj54 on February 20, 2012 at 14:34:30 from (50.36.173.13):
In Reply to: Farmall tractor gas line problem posted by mkirsch on February 20, 2012 at 14:26:39:
go thru the carb as needed
