Re: Farmall tractor gas line problem
Posted by Andrew Psencik on February 20, 2012 at 14:50:19 from (173.255.47.221):
In Reply to: Farmall tractor gas line problem posted by Donald0827 on February 20, 2012 at 14:26:39:
sounds like you still have a carburetor problem. If i had to guess, your jet is stopped up. remove carb and completly disassemble. soak in chem-dip and install new hard parts. Is the bowl filling up ? Float set correctly ? very remote chance of having fuel in the carb and it running so lean it will not even sputter. Simply put, there must be a blockage or not enough vacuum. One more possibility is an enormous vaccum leak. hard to diagnose without engine running, but possible.
