Re: Re: Re: Upper bolster bearing on H
Posted by Andy Martin on September 12, 2000 at 11:27:10 from (38.31.74.78):
In Reply to: Re: Re: Upper bolster bearing on H posted by John C. on September 12, 2000 at 09:29:52:
Have you wiggled the steering wheel? Violently.
Make sure there is not a washer jammed on the thread above the gear.
I have had several off and not had your problem, but I think I would pry gently around on the gear some to try to get it started. Since mine have slipped out, it makes me think yours may have a shoulder worn into it, so moving it around may cause it to slip off.
With enough hammer work you may damage the threads or break the gear, but ultimately both are replaceable if it has to come out.
Post A Followup
: Re: Re: Re: Re: Upper bolster bearing on H
