Re: HYDRAULIC PRESSURES?
Posted by The tractor vet on February 20, 2012 at 16:46:54 from (76.212.231.208):
In Reply to: Re: HYDRAULIC PRESSURES? posted by 706 SS on February 20, 2012 at 16:37:06:
On 706's for the most part i set then at around 235-245 when i install a new T/A . I also install at that time a new MCV pump and new spring kit in the MCV , therefore you have to check pressure and trim the pressure reg . spring to set it . When i am doing tis i have already went thru the MCV with new O/Rings and gskt. So when it goes out the door i know that i have done everything i could do to make it wright and not see it again . If you have looked over my old posts then you should know how to do the adjustments with out me going over this again. BUT i will if ya need me to .
