Re: Farmall tractor gas line problem
Posted by 504 on February 20, 2012 at 16:56:41 from (64.111.61.44):
In Reply to: Farmall tractor gas line problem posted by Donald0827 on February 20, 2012 at 14:26:39:
Give it a good shot of starter fluid, if it runs you know for sure it is a fuel problem. If it doesn t start then it is time for a compression check, assuming it has fire.
